주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 Apple MacBook Air 중 더 작은 노트북.
149 질문 전체 보기
Is it possible to replace clutch cover on MB Air 11"?
Hello,
I'd like to replace a broken clutch cover on a Macbook Air 11" Mid-2013 (A1465) and I cannot find a reliable step by step walkthrough. I'm pretty new to teardowns, and while I have all the gear, if anyone could provide a guide or atleast point me in the right direction, it would be much appreciated! :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It slides horizontally about a quarter of an inch, you squeeze it and it comes off.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Do I need to take the display apart first, or can this be done with only the steps above?
It needs to slide along the axis, so yes you do need to get the display part off to make room (the least risky path). If you've done it a few times it can be popped off (depending on how damaged it is) but you tend to need to take the display off to slide it back on otherwise you can damage it in the process.
댓글 달기
귀하의 답변을 추가하세요
Devon Fox 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 392
