주요 콘텐츠로 건너뛰기
카세트 플레이어의 수리 안내서 및 지원.
85 질문 전체 보기
The Cassette deck in my car doesn't play music! Please help
It was working just fine. Then it started making these high pitched sounds whenever I had the iPod adapter playing. Now it won't play any tapes at all. The radio still works, so I know I didn't just blow out the speakers or something. It still sounds like it's spinning the tape and it doesn't eject or rewind anything.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
The most likely culprits are
#1 the belt that controls the cassette mechanism has gone bad/loose or broken
  1. 2 the switches that control the mechanism are dirty or broken
Both would require removal of the unit from the car and you'd need to bring it to a electronics repair shop. Any decent tech would charge $75-125 to do it right. They'd also clean the heads and tape path, so it'll probably sound a lot better once they are done. good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Shelly 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 40
전체 시간: 10,113
