The USB cable is stripped in my garmin .
Need to replace the plug.
좋은 질문 입니까?
You should be able to replace the cable with a standard USB cable similar to the ones used for portable Hard disk Drives. ie slightly bigger than the ones used for android phones. It will have a standard USB connector on the one end and a smaller connector on the other. You then buy a cigarette lighter 12 V USB charger from any of the cheap 2 dollar or gas stations and off you go. You are bound to have a cable lying around somewhere!
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 50
@joehammer post some images so we can see what you see. Is the issue that you need to replace it or that you need to find a new connector? 기존 질문에 이미지 추가하기
oldturkey03 의
