Battery problem in Braun electric toothbrush 3D D 15511
Can this can be repaired
좋은 질문 입니까?
In theory yes, in practice...that depends. I have a similar model that failed and I opened it up to see if I could just replace the battery, The problem was everything was corroded to near death inside. The battery is not designed for easy replacement and everything is soldered in place. I found the defective components and was able to order them (IC's & Battery) but the logic board was in very bad shape.
So I would certainly try, otherwise the tooth brush will just end up in the trash. Hopefully you'll have better luck than I did.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 117
