Can I put a 2TB hybrid SSD into an early 2011 MacBook Pro?
can I put a 2TB hybrid SSD into an early 2011 macbook pro? 2.66Ghz w/ Yosemite OS X.
좋은 질문 입니까?
좋은 질문 입니까?
Your system has a SATA III (6.0 Gb/s) HD interface which can support a 2.5" 7mm high drive. So you do need to be careful the drive is not to high.
The Seagate SSHD: Seagate FireCuda is a good choice or if you are looking for a SSD drive the Samsung 850 EVO is also possible.
해당 답변은 도움이 되었습니까?
I'd also change out the hard drive I/R cable to the 2012 cable when doing this. MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Put electrical tape on the bottom of the hard drive bay as it is know to be rough and damage cables.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,557
댓글 1개
Are you are asking if you can put in a 2TB SSD or a hybrid SSHD to replace your current hard drive?
Dan 의
