주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
replaced LCD screen, phone went dead. turned on several days later
So, I replaced my cracked lcd screen, which I have done plenty of times, and when I tried powering the phone on, it wouldn't. The battery was fully charged at the time. I replaced the new lcd screen and put the cracked one back again, still dead. I don't believe it was the new replacement screen since I connected the cracked screen and still had same problem. Anyways, Three days later I tried turning it on again and surprise! It works back again. Has anyone experienced this problem before? Or know what could have caused it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Its possible that you caused a non-fatal short when plugging in the new screen. I have seen a short prevent the display from functioning even when replugged, and the device power cycled. The 2 ways I've seen devices restored to full functionality was a soft reset or a full cycling of the battery itself (drained to zero then charged until boot).
Of course this only applies if you (one of the following) left the phone on/the battery plugged in/were not properly grounded when performing the repair.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gabby 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 44
