주요 콘텐츠로 건너뛰기
다양한 TV 브랜드 및 스타일 안내서 및 지원.
9023 질문 전체 보기
TV will not turn on. No LED.
Panasonic TC-P50S30
I have replace the Power board, still nothing. I am getting 10 volts on P6 (it says 5v on the board), and I am getting 10 volts to the switch. Still it will not turn on. What next?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
The voltage is actually 5v (I didn't notice the doubler was switched on).
댓글 달기
답변 1개
Have you tried checking the outlet?
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
If you are referring to the wall receptical, yes. There is also 120v at the connecter on the power board. There is also 5v at the standby pin on the main board. I can find no fault with the power board, and I have also replaced the board, still no start or standby led. I have just ordered another main board, and I'll keep you posted.
Got another main board, and the tv powers up, but the picture is horrible. Brights are whited out, and the darks are blacked out.
I sent that Main bd. back and got another one from another vendor. TV works fine and the picture is as outstanding as it ever was. Problem solved!
댓글 달기
귀하의 답변을 추가하세요
Al Burr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 86
