Front left power window does not work,.
2002 honda accord automatic V6 four door .
Front left power window does not work,20A fuse is ok.What to check next? Thanks Ivo
좋은 질문 입니까?
좋은 질문 입니까?
> does not work
Does it try to run? Whirr? Klunk? Or totally silent?
There is a 20A fuse (#15) for the windows, but also a 7.5A fuse #13 for the "multiplex" brain. I'd think a dead multiplex would cause many troubles, but check it anyway.
The switches, relays, and multiplex brain are all-in-one. The factory diagnostic is many pages of tedious tests, and the end result is replace-the-unit.
So check the motor. See attached image from the manual.
If you can hot-wire the into working, but not via the switches, replace the whole door-module. A good auto salvage operation should have these.
This is from the 4cyl 2002 Accord. The V-6 model is different in many ways. You'd think they'd use the same window-motor?
해당 답변은 도움이 되었습니까?
How can I download the manual?
24 시간 전: 0
7일 전: 7
30일 전: 18
전체 시간: 13,381
댓글 1개
Looks like the window was just stuck.Thanks anyways
Ivo
tumai 의
