Put the mobil in the water
What ami doing wher my mobil put within whater
좋은 질문 입니까?
Yaman Alsayad You will have to treat it the same way as any other water damaged device. First do not turn on your phone, charge it or try to connect it in any way. Remove the battery as soon as possible from the phone to minimize further damage. After that completely disassemble your phone by using these guides. Using 90%+ isopropyl alcohol, clean your phone by following this guide. It was written for an iPhone but all the points are still pertinent to your phone as well. While cleaning, check for obvious missing or damaged components. you can always post some images of your boards etc. with your question so we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that.
Once it is properly cleaned, replace the battery and reassemble your phone. then you can properly troubleshoot.
안내서
난이도:
어려움
1 - 2 hours
안내서
난이도:
아주 쉬움
2 - 5 minutes
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 34
