Replacement battery won't charge
Successful replaced my iPhone 6 battery but it won't charge past 1%
Any ideas
좋은 질문 입니까?
취소
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
평점: 1
Any ideas
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기It is possible that your replacement battery is defective. It also sounds like the problem was more with the charging circuit than the battery.
If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current when it says it's charging.
I would try a known-good battery to eliminate that possibility. Otherwise, you will need to have your phone looked at by a micro-soldering repair shop.
평점: 1
Did it charge before you changed it ?, if it did you have a bad battery. If not you more thank likely have bad tristar and / or active diode.
댓글:
If your previous battery did not charge at all you should check the charger. Check the voltage across the terminals with a DC voltmeter. If it has some value close or higher than nominal battery voltage the new battery most likely has a problem.
Vasilis Caravitis 의 답변
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 96
