Try raking the bottom of the lightning socket with something thin and stiff, such as a thin paperclip (or use the Probe and Pick Set) to remove the lint.
I had a similar issue with my iPhone 5S and the Apple Store guy took it back for 3 minutes and came back and all was well.
One giveaway is that the white plastic collar (for lack of a better term) doesn't sit flush against the phones body when the lightning cable is plugged in. Once that lint was removed, it was flush again and charging was back to normal.
[Update]
TL;DR
Toothpicks (wooden tools) are safer but may not tough enough.
I used metal tools but was careful not to mess with the metal pins.
___________
Yes, a toothpick (or anything wood) is certainly a lot safer than metal tools. The toothpicks I've used aren't hard enough to break up the cruft at the back wall of the port.
You could use a teflon spudger as an in-between that's stronger than wood but can't do damage like a metal pick would.
That being said, I recently had to clear out the lightning port a second time (on my iPhone 6s) and I used my metal tools without issue. The pins are located on the floor/ceiling of the port chamber so I mostly kept clear of the pins by sticking to the back wall to break up the packed cruft.
댓글 6개
i have this problem to
Roblox builds 의
I too have a problem charging iPad Pro !!!
All the cables I have including original Apple bought recently , are useless. They are not recognized by the tablet.
Fortunately I still have an old cable that I bought a long time ago but did not use it regularly because it was not long enough. By accident I did ‘t throw him in the garbage..I still have the cable that I have been charging for a long time but I used some force because it was not long enough. By accident I did not throw him in the garbage. Desperate I searched a solution when I saw that I can not load my iPad Pro fo witch I pay a lot of money. And surprise . It loads it. All those recently bought did not. Then I went to a store and asked to sell me lightning cables for two years ago. They flipped through the warehouse and gave me the last three pieces they had. Surprise again . ALL HAVE BEEN RECOGNIZED BY THE IPAD .
Conclusion ? Either the old cables have something extra or maybe the recent production one has something missing .
Dni Tm 의
I can’t charge my phone in less I push the charger slightly up are it twards me other wise it won’t charge at all so basically I have to leave my phone resting on something my the chargers or I have to hold my phone at an angle and push the charger into the surface I’m sitting at any way to help it?
Ashy Kie 의
i am having the same issue with my iphone 6s and it is very frustrating coz i have to have the charging cord over my old glasses case while plugged into phone so it will charge
Maddie Guy 의
Thanks, I used a little brush and it worked.
I have been so aggravated by this.
Cindy Burgess 의
댓글 1개 더보기
