주요 콘텐츠로 건너뛰기
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
20 질문 전체 보기
I would like to identify a broken flex in the upper right corner
I would like to identify a broken flex in the upper right, just to the left of the rear camera. There are 4 snap connectors here.....this one that I have broken, then 2 others and then the rear camera (extreme right). It's the smallest of these flex connectors and I'd like to identify it to test the operation and to order a replacement.
In the photos the red spot is visible where the connector has started to separate.
Can anyone help please ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 5개
Can anyone identify this flex please ?
I wish i could for you. I'm not sure what that is responsible for.
I have since found that the iPad has no 4g connection when it has a SIM card .
So I think now that the flex is connected to the cellular aerial.
Can anyone out there confirm this or recommend the part that I need to order and replace.
A complete new cellular unit came with this very small flex (the complete Unit was very inexpensive in the end ( <$4)
I just got my comment flagged but i don't think you can post links. Look up "4G ANTENNA FLEX CABLE FOR IPAD AIR 2 (RIGHT SIDE)" from mobile sentrix
댓글 달기
답변 2개
가장 유용한 답변
Take a photo of it and post it here.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I realize this is five years too late, but for anyone else who comes across this, this cable is the right LTE/cellular antenna connector. It is grafted to the black module along the top of the device between the rear and front cameras, and connects to the logic board via a small coaxial connector.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
malcolm watson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 385
