The ringer is on but the phone won't ring?
I have a 32gb iPhone 3gs. When I first got it the ringer worked fine. Now when I get a call it doesn't ring. I have vibrate on and ringer on. Is there some sort of setting I can change?
좋은 질문 입니까?
좋은 질문 입니까?
Well, I found out what happened. I inadvertently swithched the ringer off. There is a button right above the volume buttons on the side of the iPhone that controls the mute. I had switched it off my mistake.
해당 답변은 도움이 되었습니까?
Silly sausage!
yes, the mute button was switched off on me as well. must have happened when i cleaned..... thanks to this site
Thank you! My phone case doesn't allow for me to see/use that button. I had forgotten it was there. Have been wondering why alarms work, but phone won't ring.
You helped me too!!!!
Thanks put a new otter box on turned the sound off duh!
No1 check is to clean out headphone jack of dirt and fluff. It sometimes tricks the phone into thinking headphones are in!
No2 check settings general sounds
No3 press and hold power and home for 10 sec until apple appears then allow to reboot
No4 replace dock or mic/speaker flex on dock( replacing entire dock is easier)
해당 답변은 도움이 되었습니까?
Thank you!!!!
Thank you so much, the ringer off button was also off on my phone. I'm a happy camper now. Barbara
해당 답변은 도움이 되었습니까?
May 2017 (six years after the original question above) & the answer has just helped us too. Thx so much! We've missed countless calls for months on end because we could not get the phone to ring incoming calls. Cheers from Minden, Ontario Canada (can you hear the rejoicing all the way across the miles? LOL)
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 34,047
댓글 1개
Thank you, I got mine working...really helpful.
Cristina Aguilar 의
