My tablet it stuck on the rca welcome screen.
My tablet is stuck on Rca booting screen and will not proceed. I have done numerous resets and restarts and nothing is working. I need help!
좋은 질문 입니까?
좋은 질문 입니까?
@kelbmass15 you are not telling us exactly what you tried. So let's start with that. You said you tried multiple resets and restart but I would try the "Hard Reset". Doing this will erase all your data on the tablet,
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet.
Should this fail as well than you most like have problems with your firmware and will have to try to update/repair that.
해당 답변은 도움이 되었습니까?
Would like to get some real help
Absolutely!! I've tried all that crap! I'm calling the BETTER BUSINESS BUREAU and filing a complaint! This is ridiculous. I want a NEW, FUNCTIONING, tablet. One and a half hours on the hold and hung up. Customer service and support is worse than terrible.
i tried everything but still nothing
@Essence Pinckney what make and model tablet. Exactly what did you try? What is going on with your tablet? The more information you give the greater your chance of getting some helpful answers
Well i just need someone to tell me how to fix a frozen welcome screen. I beg of your help please and thank you. :)
해당 답변은 도움이 되었습니까?
Hi Kelby
If you fill out his form you will receive a repair authorization number and the address to shop you unit to.
This form is for warranty repairs and non warranty so they will be able to assist you. The link for the form is below. Hope this helps answer your question.
Use preauthorization code: MKM116
Best regards,
Rhea
해당 답변은 도움이 되었습니까?
I have been on HOLD with RCA support for 1 hour and 15 minutes!! I'm hanging up and calling the BETTER BUSINESS BUREAU. This is ridiculous and I'm furious!!!!! Never used this tablet
this is a new tablet!!
If your tablet is stuck on the dog screen what I did was reset the tablet by using a paper clip and putting it in the hole and now try the steps that it says since it is turned off
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 11
30일 전: 48
전체 시간: 14,834
댓글 7개
Why does my voyeger tablet
stay stuck on the welcome screen
chadbowker07 의
I have resurrected one of these tablets from the trash. It charged... Factory reset... And button g several times. Each time it it starts and stops at the welcome screen for choosing the language... The touch screen is not able to select English. Do I need to replace the cracked screen first???
Help... Bert
letropare 의
Help... Bert
P.s. where can I get a pdf of the repair manual?
letropare 의
I have the same problem
Daniel Battaglino 의
My RC tablet is stuck on logo also I can’t get it off or do anything with it
Lori Mchenry 의
댓글 2개 더보기
