주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2015년 3월 업데이트는 5 세대 Intel Core i5 및 i7 프로세서를 장착하고 배터리 성능이 약간 향상되었습니다.
136 질문 전체 보기
Black Screen and does not take charge
The Macbook was off for 7 weeks while I was on a business trip combined with vacation. It was fully charged when I left it but it didn´t turn on only with battery power when I first tried after that period. I connected the charger and it booted OK showing 0% charge on the battery. I left it charging but the screen soon went black again and the charger connector light went off. After that I can no longer get a light on the charger connector at all (green or amber) and the computer will not turn on. The charger is good as it works just fine on my other Mackbook Air 13". I fully cleaned the Magsafe connectors (both on the charger and on the Macbook) and also opened the back of the Mackbook to disconnect the battery but that didn´t change anything. The charger does not light up with the battery disconnected or after I reconnected it. I should mention that for several months before I left the computer off the charger light would not light up the first time I connected it to the computer. I had to wiggle the connector up and down a few times and it would take a while before I got any light on the charger connector. Could this be a bad I/O board? I´m ready to order one but I´m afraid to spend $100 and find out later it was a bad logic board.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개:
Thanks for the answer Sternbergbob. The laptop was never dropped or mishandled in any way. It has always been carefully handled actually. Unfortunately, I have been on assignment with my company in the NE of Brazil for the last 2 years in a relatively remote place with no access to an Apple store. This may in fact be related to the fault as I've been living in a house right on a tropical beach. I keep all my electronic gear inside sealed plastic bags whenever not in use but, still, the salty air gets into everything. I still have 1 year to go in this assignment and have no experience with micro welding so already ordered a new I/O board from this site. I'll let you know if it fixes the issue once it arrives, hopefully in the next 2 to 3 weeks. Thanks again for the help!
댓글 달기
답변 1개
Sounds like a power port problem to me, if you have any experience soldering or micro soldering that would be my first recommendation. That failing I would recommend a new I/O board. Has the laptop experienced any falls? Another good step would bring this problem to the apple store as they might be able to diagnose further or recognize this issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
enioadriana 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 845
