주요 콘텐츠로 건너뛰기
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
What's wrong with this circuit board?
I have had a recurring problem with the Circle Pad, and it all now leads to the circuit board inside its module.
When I move the analog stick downwards, even when pushing it all the way, the controls will never register a full-speed DOWN movement. When moving it in a full circle, instead it will make an oval-like shape. I tried calibrating it, but it always fails. Cleaning it with alcohol didn't fix it either, although I used ethyl alcohol.
There are visible scratches (don't know if they're scratches or corrosion) on the stripes where the slider contacts meet with the circuit board on the left side, yet only a small portion is actually affected.
What can I do about it without buying a replacement?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Don't use ethyl alcohol! Use isopropyl, as high purity as possible.
That must be it. No wonder nothing changed when I cleaned it with ethyl.
댓글 달기
답변 1개
선택된 해법
Nothing. Get a new one. It seriously costs under 2$
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
after four years i finally replaced it. thank god i live in usa now
댓글 달기
답변을 추가하세요
Omnimatrix10 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 152
