주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone works, but battery won't charge up unless I bump it.
So this one's weird, had this issue for a while now.
My iPhone 5S after doing repairs on it, seems to have this problem where the battery will not charge. ( Lightning bolt and charging indicator is showing, but % will not increase when plugged in. )
However, if I bump the phone, it'll start to charge again until go about my day (carrying it in my pocket)
I've had this issue for a couple years now.. but it seems to have become worse..?
I'm able to see whether the battery is charging with an iPhone tweak called 'Battery Life' telling me whether the battery is receiving mAh charge input or not.
So yeah, bumping my phone is the temporary fix to make it charge.. what is the reason for that?
Obviously it's hardware related..
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Hello,
If you plug in the cable does the metal part completely go in?
If not its possible theres alot of dust in it blocking the power.
But when it indicates that its charging then it most likely is a motherboad issue. ( power ic lose or needing to be replaced) i would first try with a different battery and ligthing charger to be sure.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Let's skip dirty charging port, cables and batteries and stick with the phone internals here. ;x
LOGICboard is fine, as far as I see. No damage and all screws not overtightend to print breach.
How is the IC 'loose' isn't that a chip on the board..? Unsure how a bump would change something so fragile and light weight.
Whatever it is has to be heavier.. could battery position dictate this?
no battery position should have nothing to do with this, my money is still on motherboard ive these kind of things before. A phone didnt charge if you held it, put if you lay it down on a table it works. This was also power ic.
댓글 달기
i think, the U2 USB charge IC or 1610A1 ic fault,
need check the current by multimeter
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
D'no how that's got to be the issue, a bump of the phone changing whether something like that works or not?
Can't be.
댓글 달기
귀하의 답변을 추가하세요
Sumona Florence 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 131
