주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon Rebel T4i는 Rebel 시리즈의 일부로, 18메가픽셀 센서와 LCD 모니터를 갖춘 디지털 일안 반사식(DSLR) 카메라입니다. EOS 650D 및 EOS Kiss X6i로도 알려져 있습니다.
little battery cover switch.
Hello,
my 650D could no longer turn on.
I found on the Internet a note that it could be the battery cover switch (little secure switch when you open the battery-cover). As I pressed the little switch with the screwdriver the eos turned on. :D
In the Internet I was supposed to bend the small switch with the screw in the middle. At the attempt the switch broked : /
Now my questions:
Can this switch or the board be replaced?
If so, what is the description of this board-part?
Can you simply bridge it? (I can solder)
I would like to unscrew the camera when I know more about it.
Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
If you can manage to find a replacement switch, it could potentially be replaced. The better option generally will be to just replace the whole board. The switch is located on a PCB board separate from the main PCB board and you can find the board for roughly $25-$40 on eBay.
There isn't a specific part number for the board as Canon considers the board to just be a part of the mirror box assembly. However you still can find the individual board being sold on places like eBay. Based on what I've found, it seems like that specific board is generally referred to as the "Power Board". Below is a picture of what that board looks like.
이미지
Keep in mind while searching for parts that the camera is also referred to as both Canon Rebel T4i and Canon 650D.
Bridging it should allow the switch to simply be bypassed. However I'd recommend against this option simply because the switch is there as a safety feature and bypassing it could potentially lead to other issues.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Contact Alzo Digital, CT, USA
Ask for service & repair divisions.
You can contact by phone or email if you are out of USA.
Request nicely for Joseph, I think, and he assist you with ATG.
이 답변이 도움이 되었나요?
점수 -1
댓글 달기
답변을 추가하세요
Michael Amann 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 18
전체 시간: 949
