주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6은 Galaxy 라인의 다음 주력 제품입니다. 곡선형 스크린 버전은 Galaxy S6 Edge로 알려져 있습니다.
496 질문 전체 보기
Am I using too much heat while changing just the glass on S6 repair?
I have tried on two displays to separate the LCD and front screen. The closest I got at being successful, I had used my hot plate set at 125 C. When I finally got them apart the long sides of the screen had curled up. Now, I understand that these have a "polarizer", is that what seems smokey? That is what curled up on me. These are not cheap to buy everyday to practice on. If anybody could help me out here it would be greatly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
선택된 해법
I think I found someone who answered the question about heat best.
Screen heating temperature measurements Gave a similar opinion about heat.
125 C /257 F is really high. Most of the time you start off in low heat and gradually apply or slowly increase to about 80 C/ 176 F.
Rule of thumb when I do screens or phones that have glass is if it's too hot to hold then it needs to be cool off.
That's why I prefer a heat gun / hair dryer. Slow and easy does it.
Hope this helps
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
I normally used hot air gun not the soldering one but the heavy duty plumber or car dent fixer use. And deprecate with visiting card. It's easy when you know the heat and gentleness
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Rick 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 209
