Why do I have sound and no picture in my 2 yr old tv?
The Samsung 60" LED TV UN60FH6003FXZA tv screen goes totally black and there is no picture
좋은 질문 입니까?
좋은 질문 입니까?
@dougger sound and no picture is usually an issue with the main board. Make sure that you check all the inputs. disconnect everything from your TV (surrounds sound etc.) then just plug in one input (HDMI, Composite, Coax etc) and see what you get. If you have the same issue then you want to unplug your set and take the back cover off. Check all your cables to ensure they are properly seated and not tore. Then check all your boards. Look for obviously damaged looking components like domed or leaking caps. Post some images of all of your boards so we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that.
해당 답변은 도움이 되었습니까?
My tip: double check the 3 white yellow and red video and audio cables to see if they are mixed up or plugged in. Ive had this problem when plugging in a TV to a console.
It may not work, but its a tip :)
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 60
