주요 콘텐츠로 건너뛰기
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
386 질문 전체 보기
home button not working but work if I jump the 2 prong
hi replace an digitizer of an ipad 3th and the home button is not working but if i jump the 2 gold prong where the home button make is contact the lcd open...
i tried an other home button and usb flex same problem
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
가장 유용한 답변
Hello, most commonly, the home button module on the digitizer is not aligned properly. It is important to check the orientation of how the old home button was installed on the old or original digitizer that was removed. If you have aligned it properly, I would highly recommend for you to order a new home button.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Check the bracket placement and that there's no adhesive over the edge keeping the button from sitting too high causing no contact.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Reparactif 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 55
