How do I share files with my SD card in order to get more storage
I cannot figure out how to sync my SD card with my phone so that I can have more storage other than just internal storage on the phone.
좋은 질문 입니까?
좋은 질문 입니까?
I found this on the internet for the J3. It's probably an identical (if not then very similar) process.
From a Home screen, navigate: Apps > Samsung folder > My Files
Select an option (e.g., Images, Audio, etc.).
Tap MORE (located in the upper-right).
Tap Edit then tap the desired file(s).
Tap MORE.
Tap Move.
Tap SD card.
Navigate to the preferred folder then tap DONE (located in the upper-right).
해당 답변은 도움이 되었습니까?
If you have Android 6+, you go to Settings --> Backup and Storage, select the SD Card, and select "Format as Storage". This will wipe your SD card and format it to be used as combined storage with the existing storage in the phone.
해당 답변은 도움이 되었습니까?
Hello,
If you want to increase your internal memory via sd card
# you need a SD card to put into your phone and then switch on your phone.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 564
