I had the same problem.
while I was on my bike I accidentally pressed some button combination
possibly JBL Connect + Volume up
It didnt turn on again.
then I opened it up, rooted around without any result and closed it up again.
not very difficult
BUT
BEFORE you open it up try the reset option
plug it in, as soon as you hear the "here I am" sound
remove the cable and press
Volume UP and Play / Pause buttons at the same time and hold them until a hard reset occurs.
here are some button combinations for the charge 3 I found on reddit
JBL Connect + Volume down
says the firmware number and blinks battery level diodes matching said numbers (coincidence?)
Volume down + Bluetooth 10sec
turns off inbuilt EQ (and limiter?)
weird mode, possibly FW update mode
(to go back, connect to powersource and hold the combination again)
Volume up + Play/Pause
resets the speaker
lets all bug JBL about releasing the button combinations for Flip 4 as they are nowhere to be found
#JBLCmon
댓글 36개
ok so I have the same problem and spent the last 2 hours looking online for a solution. I really love this speaker and was so sad to see it brake. after looking and looking for a fix and getting NO WHERE I got to !#^&@@ I through it at the ground. I almost cried when it immediately started working again. I think I originally broke my speaker by dropping it and this 2nd drop seemed to fix the problem. try dropping it on carpet so you don't brake anything else. hope this helped
patrick pierson 의
my friend conected it in a computer and it semedto work ive been trying it but couldnt find a charger
Kevin Almanzaacosta 의
Connection to computer helped me. Thanks
PrinCesS 의
i have the same problem, and i did connect it to the computer using its chord but still won't open.
Ricky 의
I have the same problem... the PC connection didn't help! Any other suggestion? Thanks, Kim
TheSpace 2000 의
댓글 31개 더보기
