주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
164 질문 전체 보기
Change 512 SSD to higher capacity
Hello,
Does anyone know where the nomal 512 SSD is situated.
I would like to change the 512 GB SSD into a bigger one.
In the tutorial there is only a description how to change from a fusiondrive to SSD. Implements that the SSD on the backside of the mainboard has to be changed.
Now my question: where are the "normal" SSDs placed? Are they in the place where normaly the HDD are placed or do you need a special 2GB SSD which fits in the slot on the backside of the mainboard? ...for it is a big difference just to take out the display and fan or to tear down to the mainboard
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 1개
Hi there,
I believe the Blade drive SSD (Apple Proprietary) is located on the back of the logic board, if your model came with a Fusion Drive. You can just replace the regular 2.5" rotational HD with a 2.5" SSD, the Blade drive replacement will be very expensive. Before you do so, make sure to backup your unit, if you break the fusion link you will lose all data. Also if you are doing the upgrade yourself, be very careful when removed the Display the glass and the LCD are fused, and if you are not careful you will crack the glass, which means a complete the LCD+Glass replacement.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Hannes Fisser 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 120
