주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
After battery replacement unable to restore with error 50
Dropped my phone in the lake, I reacted as fast as i could. After that i put the phone in rice and also dried to dry it off in the oven, nothing. So i have ordered a new battery and a new screen which both have been replaced. The phone now takes on the picture but at around halfway through the restore it gives me an error
itunes error code photo
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Unfortunately " error 50" is a very generic error code. My experience is that there is an issue with your phone trying to connect to Apple's servers, and its being interrupted. It could be numerous things from your sim card connection, your WiFi antenna, a chip has been fried, even 3rd party app interference (unlikely). Try using wifi to connect to servers and see if that works, then try connecting to itunes via a Mac or pc. Back it up if possible. If some work but others don't you know where to start.
Another thing is you could Try is !Gently! cleaning sim card slot and sim card with 91% isopropyl alcohol and new a soft toothbrush.
In the future rice is not a very good solution because
A. Rice is dusty and dirty
B. Rice in not very absorbent
C. The water isn't usually the main issue, the minerals and sediment that water leaves behind.
Read the guide here Repairing iPhone Liquid Damage
Here's a quick overview
If it happens again
Turn off phone right away
Then disconnect the battery as soon as possible.
Remove motherboard and clean the surface very gently, paying special attention to all the connections as per above with isopropyl alcohol and new (or cleaned) soft toothbrush.
I hope one of these help you and sorry if they don't
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The problem is, i only get the black apple logo when i try and turn the phone on, so i can not connect through wifi or anything. The battery and screen both have been replaced. At first, I got an error -1 after itunes downloaded the ios for the phone and around the error popped up around the same 60% mark
댓글 달기
귀하의 답변을 추가하세요
Rasmus Olander 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 234
