주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
20 질문 전체 보기
MacBook Air A1369 Lcd screen
Hope someone help me!
Hey Hi Guys, I have Macbook Air A1369 mid 2011. It has screen issue so I decided that replace the screen of my laptop. But laptop screen is too costly so can't afford. So decided to find dead laptop and install their screen to my laptop. I got dead laptop A1466.
Ok main question is here.
Can A1466 screen will fit to my laptop (A1369 Screen model LP133WP1-TJA1)?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Hey Thanks Guys, So What should I do now? Please suggest me.
댓글 달기
답변 3개
가장 유용한 답변
Swapping the full lid assembly;
2010-2012 lids cross compatible (A1369-only A1466 2012)
2013-present lids cross compatible (A1466 2013 onwards)
Check the serial number to find the year. If you were to install just the LCD panel, all A1369 LCDs are cross compatible, no difference in the LCD since 2010. Be wary however, I see a lot of attempted LCD only replacements which come to me, after going to another shop where they seriously mess up the backlight sheets.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Agreed! Changing the LCD panel is not easy. I only do the fully displays.
댓글 달기
Here’s the differences between these two series parts:
Just in review of the guides and parts the newer displays iSight camera lead is longer in the newer display so it does appear the units could be swapped. The screens resolution are the same but I’m not sure if the signaling is (LVDS Vs iDP). I don’t have my laptop which has my manuals so I can’t tell you for sure.
Replace a display compatible with the model A1369 Late 2010 to Mid 2011 13" MacBook Air laptop. Part #661-5732, 661-6056. Features a 1440 x 900 13.3" LCD screen. 이미지
제품
MacBook Air 13" (Late 2010-Mid 2011) Display Assembly
$399.99
Replace a display compatible with the model A1466 Mid 2013 to 2017 MacBook Air 13" laptop. Includes the 1440 x 900 LCD 13.3" screen, aluminum case and camera. Part #661-7475, 661-02397, 661-02505. 이미지
제품
MacBook Air 13" (Mid 2013-2017) Display Assembly
$314.99
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks Dan.
Check below link
Original LCD Glass 13.3inch for Macbook Air 13" A1369 A1466 LP133WP1-TJA* Display panel
http://s.aliexpress.com/UVnyMZVB
I’m a bit confused here. Are you swapping out the lid assembly or going to replace the LCD alone here?
So you are looking at replacing the screen it’s self then. The newer retina and Airs are both much harder to replace and often people damage the defused sheets so you see dark spots.
I would recommend you just replace the full lid assembly.
댓글 달기
Hi Dan so I’ve got a a1466 and I want to swap the screen / the whole lid assembly from that onto a a1369 do you you think it’s possible ? Thanks for you time
Mat
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The lids are a bit different! The cables are different length and the iSight camera is also different. Best to get the correct one and not fudge it.
댓글 달기
답변을 추가하세요
Sachin Ahire 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 3,340
