주요 콘텐츠로 건너뛰기
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 질문 전체 보기
The screen won't come on.
I was repairing something on my ds and had to unplug the screen. Once I plugged it back in and put it all back together, the green light came on, the charge light came on, but the screen didn't. I took it apart, pushed the ribon cable in as far as possible, and still nothing. I would like to avoid a new getting a new screen, if at all possible.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Hey Jack, can you please take a look at the teardown linked below and let me know which step the connector you are referring to is?
Nintendo DS Lite Touchscreen Replacement
I followed that, but I had another already setup screen on another ds I don't use anymore so I just stole it's screen, but now it doesn't come on.
And the screen did have insulation to prevent a blown fuse.
댓글 달기
답변 1개
선택된 답변
So if you have another working display, from another ds. And can test them on the other ds? And we know the board is getting power. Then check the board for any damaged components. Especially looking at the connector pins for the display
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I do not see any damage, and the ds was practically new. All I did was put in a new screen. The green light registers it's on, the orange when it's charging, and the red when it's dying.
Should I just buy a new screen?
I thought you had two of these? We need to do some testing to rule things out
댓글 달기
귀하의 답변을 추가하세요
Jack Saussy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 1,122
