주요 콘텐츠로 건너뛰기
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
77 질문 전체 보기
I used too high of a voltage on my GameCube , how do I fix it?
I forgot to use a power converter when powering my GameCube, after a few minutes something went wrong and it turned off. I can't turn it on any longer.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
John zoidberg how did you power it up
This same thing happened to me except I used the power adapter.
댓글 달기
답변 1개
John zoidberg this will depend on how you powered it up. When you say you "forgot to use a power converter" I assume that you are somewhere where the voltage is not 110V. You usually plug the GameCube power adapter into the power converter. This time you did not and your GameCube no longer comes on. This would lead me to believe that you have blown the power adapter. To be certain we would need to know for sure how you usually power it up, what voltages you are dealing with and what voltage your GameCube power supply has.
Update (09/30/2017)
Since you applied 220V where there should only be 12V you are most likely having multiple damaged components as well as probably a burned board. You will have to disassemble your GameCube to take a look at the boards. Start with this guide Nintendo GameCube Motherboard Replacement and take plenty of pictures. Post those with your question so we can see what you see. If you are lucky the damage will be contained to a single board only.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
The outlet was 220V, on the back of the console it says DC 12V 39W
did you use a power adapter at all or did you connect 220V directly to the GameCube?
I connected the 220V directly to the gamecube, I DID NOT use the power adapter at all.
댓글 달기
귀하의 답변을 추가하세요
John zoidberg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 24
30일 전: 36
전체 시간: 1,855
