์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 ์งˆ๋ฌธ ์ „์ฒด ๋ณด๊ธฐ
Tablet doesn't turns on or charge. Overheating at the right sup corner
Everytime I attach the battery or plug the charger the tablet won't turn on but instead it overheats. The heat come from where the processor is and it get very hot. I used a multimeter to see if there are some power supplies issues and the battery looks fine with 3,7V. I already tried disconnect and reattach the battery but it still doesn't work, even tried to plug the charger without the batery and still the same.
I starting to guess that it might be a motherboard issue. Has anyone here experienced something similar?
Actualizaciรณn (02/10/17)
Here's a photo from where the heat comes from:
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๋ฅผ ๊ฒช๊ณ  ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 8
๋Œ“๊ธ€ 12๊ฐœ
I have the exact same problem with my Nexus 9
Did you end up finding a solution?
Carlos
I have a Amazon Fire Tablet and it heated up really bad where the power button is. Now it just wont turn on...even when charging or holding power button Down! Does anyone now how I can fix this?
I ran into this problem after plugging in a Samsung USB adapter into my galaxy tab SM-T560NU. Battery life was hovering at 53%. Plugged in the adapter and the battery died instantly. ? So I plugged it in and the %#*@ thing started heating up. Still won't charge and I'm not willing to go the distance with this thing to see if it goes ballistic.
This is a common issue with most tablets and usually it starts affecting it the older it gets as the MotherBoard could break down. A short term fix that I've found is to cool the tablet by placing It on an ice pack or putting it in the fridge for a minute or 2. This could help to turn it on but is again only short term.
I have same problem it keeps heating a motherboard don't know why, the think is it was working just fine before I had to charge it and since then I couldn't switch it on or see if it charging.
๋Œ“๊ธ€ 7๊ฐœ ๋”๋ณด๊ธฐ
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 6๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
I read somewhere else and this worked for me
โ€œMy tab2 also refuses to charge if the battery gets too low. This is how I fix mine.
Disconnect charger
Hold power button and volume up button for 30 seconds
Keep holding buttons while plugging in charger
Hold buttons for another 30 secs
Release power button keeping volume button pressed
Tab starts to charge
Billโ€
ํ•ด๋‹น ๋‹ต๋ณ€์€ ๋„์›€์ด ๋˜์—ˆ์Šต๋‹ˆ๊นŒ?
์ ์ˆ˜ 3
๋Œ“๊ธ€ 2๊ฐœ:
Yeah this didn't work, not the solution for what we need.
Yes it worked... thank you
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
I literally just barely had this issue with my iPhone about an hour ago, so I went to this website and found the answer- there is something to do with the battery that once it dies and your device gets hot, the battery needs to be reheated- some people recommended applying a blow dryer, some said put it between 2 cable boxes that emit heat, and one said take off any kind of case you have, plug it into the charger( I actually don't even know if that's necessary, but it's what I did) and rub the battery area between your hands for about a minute or until you get some kind of response- good luck!
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
I have the same issue with my tab S. I got it checked from a local tech and he confirmed that Power IC is heating up and needs to be replaced. As Samsung is just selling the tabs and not giving repair services in Pakistan. I got brand new ICs from Ali Express. On replacing the IC, my device didnโ€™t turn on. Now the techy is saying that its processor is shorted which I am not agreeing.
Before turning on, device has nothing to process. Why it is heating up on charging in โ€˜off stateโ€™, still a mystery. But I am not giving up and will update if some luck comes in the way.
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
This is a common issue with most tablets and usually it starts affecting it the older it gets as the MotherBoard could break down or short circuit some parts. A short term fix that I've found is to cool the tablet by placing It on an ice pack or putting it in the fridge for a minute or 2. This could help to turn it on but is again only short term. But keeping the device cooled and turned off when charging to help limit heat to the motherboard will save the life in the long run.
์ ์ˆ˜ 0
๋Œ“๊ธ€ 1๊ฐœ:
What if you can't get it to turn on at all?
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
I have a Samsung Galaxy tab A SM-355Y. About 4 months prior it started to get hot when charging and using. Then one day whilst charging it got VERY hot and never turned on again.
Today l received a brand new battery for it, l then put it in (very difficult to open case), but following a YouTube video l managed to replace the old one.
About 1.5 hours into charging it up, l felt the back of the unit, and, as youโ€™ve probably guessed, hot in the lower third section. So, it wasnโ€™t the battery at fault!. So then l let it cool down, and then switched it on again (to try and isolate exactly where the heat was radiating from). The location turned out to be -, if you can imagine dividing the back into six sections - one line down the centre (top to bottom), and two equal lines side to side - now if you measured 2cm up from where the USB cord goes in and drew a line around a small soup spoon (between the two lowest sections of the case), that is where the heat emanates from. Now, having given that location, l have to tell you about a very strange abnormality, right bang smack in the centre of that โ€˜spoonโ€™ shape, is something l that can only think of to describe as a โ€˜pimple likeโ€™ bump, (raised from the inside of machine, the bump being proud on the outside of the case) - l can give an exact location, - 4 cm up from USB port, in the dead centre. Possibly, what ever is causing the problem is behind that, and the raised โ€˜pimpleโ€™ has been caused by the heat of a faulty component directly behind there!
Can anybody shed some light on this, particularly what is directly behind the โ€˜soup spoonโ€™ and the โ€˜pimpleโ€™ areas?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
When charged it is overheating at the top and then the bottom stays cool when I try to plug it in it plugs in doesn't come on and then I try to press the power button but I just hear sounds
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๊ท€ํ•˜์˜ ๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
ort ๋‹˜์€ ๋Œ€๋‹จํžˆ ๊ณ ๋งˆ์›Œ ํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
24 ์‹œ๊ฐ„ ์ „: 9
7์ผ ์ „: 50
30์ผ ์ „: 261
์ „์ฒด ์‹œ๊ฐ„: 18,449
