Ac vents don't blow comes out defroster
When a.c. is on it will only come out the def or floor that it other that that it works fine
좋은 질문 입니까?
좋은 질문 입니까?
Hi Robbydanny, that problem happens when there is an issue with the vacuum system. I would suggest popping the hood and looking at the vacuum lines for any cracks or leaks. Replace the lines that are damaged and if you can, swap out the hard plastic lines for flexible rubber vacuum rated hose.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 158
