No sound only while playing music, Auxiliary connection works
I've been facing no sound issue only on Bluetooth connection while playing music, it works fine for calls and auxiliary connection. I've tried doing a power drain and recharged my device, also tried a reset however still can't play music through Bluetooth. I also connected the speaker to a different phone however the problem is still there.
Thanks in advance.
좋은 질문 입니까?
4 댓글
Hi @talhatahir ,
Assuming that you can BT pair the speaker successfully, does it work on BT if you have the charger connected (and switched on) to the speaker?
jayeff 의
No, it doesn't unfortunately.
I am able to make calls through the speaker it's just the music that doesn't play through BT.
Talha Tahir 의
I would try resetting (power cycling) your bluetooth device and the JBL. Unpair the JBL and re-pair the Bluetooth connection. This works with a lot of bluetooth devices.
Anthony 의
I did that already however it didn't help in resolving the issue.
Talha Tahir 의
