Power supply for iMac retina late 2014
Which power supply should I buy ? Upper one or lower one ?
I linked below.
좋은 질문 입니까?
I linked below.
좋은 질문 입니까?
Hello,
You only posted one link... This part should be good as long and you correctly match the EMC#. You can put your serial in Everymac ultimate lookup to check you current models EMC#. Opening it up and replacing the PSU is the hard part.
BTW don't forget the Adhesive strips.
[연계 제품이 누락 또는 비활성화 됨: IF174-005]
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 790
댓글 2개
As far as I can see, those are the same part. Perhaps you accidentally put the same link twice?
Rachel Acosta 의
Are you sure you need to replace the power supply? Double check your cord is good and review the diagnostic LED's what are they telling you.
Dan 의
