computer want turn on
I added memory to a dell 2400 desktop and right after i did this i went to turn it on and it did nothing. No green power light indicator or nothing. Please help!!!
좋은 질문 입니까?
좋은 질문 입니까?
Remove your memory and see (actually hear) if you get a post error code usually a couple of beeps depending no your BIOS. If you get the beeping, your CPU is okay I would reset my CMOS and reseat just one memory module and see if it boots up. You may have incompatible memory, or a module that is faulty as well as a module that is not inserted properly. What mother board do you have? I believe that for that particular PC each memory slot can hold DDR PC2700, DDR PC3200 with a maximum of 1GB per slot, and remember that your system does not support ECC. Because ECC and non-ECC modules should not be mixed within a system, install the same type of modules that are already in your system Good luck and let us know how it is going
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 399
