주요 콘텐츠로 건너뛰기
The JBL Charge was released in 2012. It features Bluetooth and 3.5mm audio for a wide range of inputs. A high-capacity 6000mAh battery provides several hours of entertainment and can charge other devices with its built-in USB port. Available in Black, Green, Gray, and Blue.
27 질문 전체 보기
It's not so can u help me
How to fix how to fix a Bluetooth problem it won't connect
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
This troubleshooting guide suggests it may have internal damage on the motherboard from a fall or water moisture. JBL Charge Troubleshooting
If it's under any kind of warranty, try and work within that first.
If not, I'd suggest opening it up to look for damage. Disassembling JBL Charge Casing
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Stefan Salvatore 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 32
