주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3531 질문 전체 보기
Mobile data Problem always E
My Sim signal is strong my fellow iphone 5s user in the house has a lte/3g working even outside my iphone is just E ihave no prpblem sending calling etc .Just the mobile data is weak my internet connection is strong also what to do i already reset it still doesnt work what to do pls
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thanks it works
댓글 달기
답변 2개
선택된 답변
Try both of these
Settings --> General --> Reset Network Settings
Settings --> General --> Reset all Settings
What model iPhone 5s do you have?
What is your carrier?
Has it worked before?
해당 답변은 도움이 되었습니까?
점수 3
댓글 9개:
Im from Philippines its always E sometimes its 3g but if it goes 3g it will not work the data just works on E i tried putting another sim nothing wprks i also tried my sim to other iphone 5s and it goes LTe/3g what to do
Is the iPhone 5s you are using from the same place as the other iPhone 5s? Without knowing the model of your iPhone 5s and which cell phone company you use, I can't help further. Different region iPhones have different LTE band support.
https://support.apple.com/kb/SP685?local...
Ok thanks :) so definitely this is not a hardware issue ?
Mine is a1533
I didn't say that it wasn't hardware. What cellular phone service are you trying to use for LTE? Different Cell phone companies use specific LTE bands.
Have you checked LTE status in Settngs --> Cellular --> Cellular Data Options
댓글 4개 더보기
댓글 달기
You could check the apn. But I'm just going to guess you've damaged the Lightning dock, using aftermarket cables. I would replace the lighting dock and see if that improves the situation
Parts
iPhone 5s Lightning Connector and Headphone Jack
Labor
iPhone 5s Lightning Connector Replacement
iPhone 5s Lightning Connector and Headphone Jack 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 8개:
DOes lightning dock affects the mobile data ?but my wifi connection is strong and definitely signal the one that is definitely hurting me is that weak mobile data
What is the cellular service company you are using or roaming with? You never answered this question.
Ok, if you really don't want to tell me what carrier you have, that's fine. According to this list, there is no LTE phone company in the Philippines.
https://en.wikipedia.org/wiki/List_of_LT...
If you are using a Filipino SIM card, it is highly likely you cannot get LTE simply because of the phone company.
Im using smart im sorry but it ahould be 3g
Ok, see if your APNs are set correctly.
Smart has some FAQs on things to check.
https://smart.com.ph/About/our-network/3...
댓글 3개 더보기
댓글 달기
귀하의 답변을 추가하세요
Fixie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 31
30일 전: 149
전체 시간: 24,964
