주요 콘텐츠로 건너뛰기
Third generation Surface Pro tablet, released June 20, 2014.
123 질문 전체 보기
Surface pro 3 won't turn on anymore.
As of last night, my surface shut off right after I turned it on. I was unable to turn it back on, even after trying all the fixes suggested on the microsoft support site. I took it to a local computer place and they said that I would have to take it to a microsoft store to fix it because it was likely a hardware issue.
Now I'm pretty sure I bought this thing refurbished, so it doesn't have a warranty. Not to mention the drive to the nearest store is really far so I'd have to plan a day to go, and probably pay a ton between gas and parking. I feel like actually going to get this fixed isn't worth it. I'm gonna try calling a couple of other places to see if they can retrieve my files, but otherwise I wanna try fixing this myself if it's actually feasible.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
@osubb let us know what the fixes were on the Microsoft website. What have you checked? did you check to make sure that your charger works and that you have a good cable? Did you check to make sure that the jacks are okay and not bend or contain debris?
댓글 달기
답변 2개
I think I am having the same issue, did you find anything out?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
No luck, unfortunately. I took it to have it looked at, but they told me I would need to replace the motherboard (which would be a few hundred bucks). And since I had gotten it refurbished, I was not able to access my files since Surface comps come with encryption. I just had them remove the chip with all my files and got rid of the thing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ogre 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 445
