trailer running lights not working at plug on truck
which fuse do i check?
좋은 질문 입니까?
Daleo Kelso this will only work if your truck has the trailer towing package. If it has been wired aftermarket, you'll have to dig a bit for it. For the truck equipped with the package:
Fuse F31 will be for the parking lights on the trailer connector and Fuse F58 is for the trailer connector backup lights.
해당 답변은 도움이 되었습니까?
Check #67 under the hood behind radiator. There is a fuse box there. I had same problem. It's a 20 amp blue 1cmx1cm square style with clear window at top. A simple continuity test will tell if it's bad.
해당 답변은 도움이 되었습니까?
trailer is working good now.
24 시간 전: 18
7일 전: 105
30일 전: 378
전체 시간: 38,232
댓글 1개
# F 150 which fuse should I check when my trailer light not working
Zane Walker Walker 의
