주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 질문 전체 보기
Can move icons around on screen, but can't press any buttons
This is a bizarre problem to have.
Did a screen replacement, using an OEM screen. Didn't have any problems with the repair and I checked all functionality before gluing it shut; there weren't any issues. However, now - as I'm trying to use it - the top of the screen (an area about 1.5" by 4", top left corner) won't let me push any buttons. I can move icons around in the affected area, but I can't press anything (like the "back" button in the Facebook app, for example). Why would the digitizer do that?? And is there anyway to fix this??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
If you check your work is the digitizer flex fully plugged in and the latch closed?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Sound to me like one of two things,
#1 what ULOCK JOCKS said witch is the flex cable could be causing you some issues due to either minor damage from the closing up process or just came unseated.
#2 in that corner of no response there could be a very minor hairline crack in one of the digitizer panels which could also be causing this issue for you either way screen has to come back off in-order for any further trouble shooting to happen on your part. Good luck let us know.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yes that was what I was going to say next snaps man!
댓글 달기
귀하의 답변을 추가하세요
Grace Wong 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 42
