One second of green light then off, was working fine, but...
picking up a bundle of DS's and DSI's so getting my fix on.
The DS was in pretty bad shape, the top screen had dead pixels and the touch screen the lower left quarter of the screen was unresponsive, along with that the dpad was not responding as it should, it needed a hard press to register.... so it bits it went
While waiting for the replacement screens I went ahead and removed all the buttons and contact pads and gave them a good clean, fine. Upon putting it all back together, I run into my fault.
-DS turns on to a green light for a few seconds and shut off. nothing is displayed on screens.
-When battery is connected and the mains connected the battery does indeed charge, but still no life on the DS.
Not dropped and hinges are fine, I do suspect water damage to some extent, but the unit used to function properly all be it with bad screens.
I will be replacing both screens but is there anything else I can test as a different fault.
what is the bare minimum for testing the bottom screen, (does the top ribbon cable need to be connected) etc ?
Many thanks
좋은 질문 입니까?
댓글 2개
Should I rule out a Fuse Issue, as the DS is charging the battery (continuous orange charge light) ?
Matthew Gipson 의
update:
DS lite completely disassembled, still not getting and life on screens, still get a green light for a second or two, then off.... an on mains the battery charges....
any way to test the screens, similar to the way of fuses ?
Matthew Gipson 의
