2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1889 질문 전체 보기
Microphone problems after replacing lightning flex cable
Everything went smooth while replacing the flex cable, however something weird is happening now. When recording a video everything works fine, but when recording a video on Instagram or Dictafone you can only hear a static noise and no sound recorded.
Any idea of what the problem might be?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
There are two microphones on the lightning flex cable assembly. Perhaps they were damaged in the process of replacing or simply defective to begin with. They are on two small tabs that each mount on either side of the lightning jack. Check the ribbon for damage like scratches, tears or nicks.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Would it still work fine while on a call or making a video through the Camera app anyway?
의 답변
Possibly and especially if the issue resides with the apps and not the micorphone. If your in call mike is working and the "Hey Siri" is working then I'd start checking the apps. Maybe uninstall and reinstall Instagram and also look at the microphone permissions in your settings.
의 답변
I've tried uninstalling and checking the microphone permissions and still did not work. While on a call mic usually works, I wouldn't say it's perfect but it works. I have noticed there's a red dot which looks like a water damage indicator (I'm not sure) but it is on top of the battery. I purchased this phone second hand, do you think that might be causing the issue? Because the volume down button is not working too.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
RDC4 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 36
