2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
735 질문 전체 보기
What does this part function as on a 6s plus front facing camera?
https://imgur.com/a/YIEIV
Today while I was doing a 6s plus repair I broke this little square off of the front-facing camera. (Image above) I am curious what it functions as.
I assumed it was the proximity sensor so when the customer puts their phone to their ear it will no longer be a black screen.
This was my first time breaking that off after several repairs. I guess it was a tad stuck in there. Also, what are some methods you use to prevent this from happening?
Thanks.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
2개의 답변
선택된 해법
Yes, that's the proximity sensor and it does stick in that plastic casing at times. When it looks like it's going to be stuck, I often try to pry the entire plastic housing up off the screen rather than try to pry the proximity sensor out of the plastic housing. Otherwise, work it out of the housing by prying all around instead of one spot or by not pulling it out by the cable itself.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thanks Greg. So the only issue the customer should have is his screen not going black when his ear is put to it?
I tested the microphone and it worked so I just decided to continue with the repair.
I think next time I'm having trouble I'll try and stick something in there and pry the plastic up like you said. Thanks
의 답변
의견 추가하세요
가장 유용한 답변
I always use a bit of heat when removing the camera flex components and the home button assemblies off of all iphone screen replacements.
Not alot...80 - 90 C for a 10 to 15 seconds softens the adhesive without damaging any of the components and never had any issues getting anything apart.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
I actually have never used heat for a screen repair. Home buttons are always super easy to get out so I've never worried about heating that up.
As far as the camera I could see using a bit of heat to help get the sensor out easier. I actually did that repair in a library so it was a bit out of the question... haha
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Ian Romprey 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 41
