주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
660 질문 전체 보기
Is the glass on the iPhone 8 plus rear camera replaceable?
Is the glass on the rear camera of the iPhone 8 plus replaceable? Do you have to replace the entire glass back or is the small glass protecting the rear camera removable like the iphone 7s plus? thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
Yes it's pretty much the same as the previous gens. Will be difficult to find the lens though :/
Difficult repair however! Super hard to get that factory seal, which just leads to dust and dirt behind the lens which will ruin the camera quality. I would go to apple first to see if they have a reasonable solution for it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
do you have any comment about this? it´s possible to get that factory seal??
댓글 달기
It is replaceable but is hard to replace it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It is replaceable difficult to remove best way is heat it up and remove it carefully.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
To be honest, i didn’t find it that hard. First remove camera from inside. Then heat up the glass en try to poke it with a flat screwdriver. Then try getting all the glass parts out. You can reheat it sometimes (makes it easier). When all the glass is removed, use a cotton bud with some nail polish remover to remove all the glue from before. After that you just need to put in a new glass, and afterwards the camera and the screen again…and done
You should take your time, and be a careful but it’s okay to do!
I hope I could help
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jimmy P 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 5,369
