주요 콘텐츠로 건너뛰기
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 또는 3.6 GHz quad-core i7 프로세서. 2017년 6월 8일 출시.
172 질문 전체 보기
Add a SATA SSD to my iMac as a second HD (Already has blade SSD)
I didn't find any upgrade kit for 2017 iMacs. I know for 21.5 SSD-only iMacs, there should be a standard SATA connector at the back of the logic board, but what about the power? Which power cable should I use? Also where should I get the rubber bumper? Any help is appreciated!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Are you sure you want to void your warranty at this time?
댓글 달기
답변 1개
가장 유용한 답변
I agree with @mayer - I would wait until your warranty has expired. I also think you can get a better solution externally than adding in an internal 2.5" drive.
Just so you can see how much work it is review this IFIXIT guide: iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement You'll need to get to Step61 so you can plug in the SATA & power cable on the back side of the logic board.
As far as the needed parts you can use the older 2015 SATA & power cables Apple is using the same cables here. The rubber cups are different which will be difficult to get presently.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I cannot seem to find the right cable. The only 4 pin power cable I found promising is this one "https://www.aliexpress.com/item/Brand-NE.... Can you give me a link to the right cable? Thanks!
댓글 달기
귀하의 답변을 추가하세요
Zhenfu Shi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 131
