iPhone Replaced Battery now sleep/wake button and video mic won’t work
Recently replaced my iPhone 6 battery. Now the sleep/wake button won’t work as well as faint-scratchy/no sound recorded on videos.
좋은 질문 입니까?
좋은 질문 입니까?
Ok, I should've just posted my answer earlier. So you've damaged some stuff while doing your repair. The power button, which is connected to the volume/mute, which you'll have to remove the battery and the logic board. It's a pretty big repair. Youve also likely damaged the front camera flex assembly. Not that big of a job. I mean you should check that and make sure you properly seated the connections. But likely you'll have to order new a new one
iPhone 6 Power Button Cable Assembly Replacement
상품
$19.99
상품
$9.99
안내서
난이도:
어려움
1 - 2 hours
안내서
난이도:
보통
30 minutes - 1 hour
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 192
Does you volume/mute switch work?
iMedic 의
Yes it works.
eric collins 의
