Smaller, thinner, quieter model of the Playstation 2 (SCPH-7XXXX) released by Sony in September, 2004.
44 질문 전체 보기
I can't find the back lid sensor of my ps2
I recently dropped my ps2 and shortly after discovered discs were no longer spinning when I turned the console on. The laser still worked fine moving forwards and backwards when I turned the console on however the motor was still not spinning. After disconnecting the entire disc section of the console, turning the console on and off and reconnecting the disc section of the ps2 discs were still not spinning. I decided this had to be an issue with the sensors however I cannot locate the back lid sensor so I am led to believe the previous owner of the console may have removed it for whatever reason. I have attached a picture of the insides of the ps2 exactly as they were when I first got the system. Any help would be greatly appreciated.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
가장 유용한 답변
quick google search turned this up
해당 답변은 도움이 되었습니까?
점수 1
댓글:
The front sensor is on the power board which I can locate easily and I think the back arrow of this image is pointing to a tab that when pushed aside allows the disc to spin which I had already pushed aside. However there is supposedly a sensor in the insides of the console to the back left of the disc tray which I cannot find and when I search on google I can't find any image that both matches what the insides of my ps2 look like and show the sensor. This is the sensor I needed to locate. Thanks for the answer though. Much appreciated.
의 답변
This is the problem. The sensor he talks about that is supposedly in the back of the disc tray is something I have failed to locate.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Albert Einstein 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 155
