주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2191 질문 전체 보기
Doesn't power on, blinks the logo when connected to current or laptop
My iPhone 4s logo comes off and on when plugged to light and laptop, when you hold the home and power button it shows the connect to iTunes symbol but turns off immediately it's disconnected from power source hence I think it wont format/restore properly, I have changed the battery (which is ok as it powers others), checked and made sure the battery connectors and terminals are in order yet the problem persist. Please what can I do?
Update (10/31/2017)
Some one please help with my question. Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
oni_erhu measure the voltage on your battery connector with the phone plugged in to a charger. Measure the voltage on the battery and check all the components around the connector. Post some images of your logicboard/battery connector with your question. Use this guide 기존 질문에 이미지 추가하기 for that. This sounds very much like a battery issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
oni_erhu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 46
