주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Needing board component names/numbers for repairing water damaged iPad
I recently purchased a water damaged iPad mini 3, after looking at the iPad under the microscope I can see the lcd connector, and roughly 5 of the sourounding capacitors/filters are visibly damaged.
I’m looking to replace these damaged parts, but can’t find any schematics for the mini 3 to find out what bits I need to order in,
Does anyone have any idea what the sourounding components are please?
I do have a picture I can email over also to help pin point which ones.
Kind regards
Harry
Update (11/01/2017)
That shows the damage done
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Yeah, I can't find anything either on ZXW. Perhaps if someone has FiveCore they can confirm if it's on that platform. I would post the picture so we can all see it.
댓글 달기
답변 1개
선택된 해법
Based on what I can see within ZXW, the mini 2 and mini 3 appear to have identical LCD connectors and layout. I have attached a screenshot of the mini 3, which has no parts identified and the mini 2 which does. I would refer to the mini 2 schematic for all of the component specs.
Not ideal but this is probably as good as you'll find. Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Funnily enough i have just been having a look at a mini 2 board I have here under the microscope compairing the two.
But that helps a lot more, so thank you very much for that! Now I just need to hope they have the same components, will get some ordered and try it though!
댓글 달기
답변을 추가하세요
harry bailey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 16
전체 시간: 235
