주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
MacBook Pro Won't power on at all!
This is a real odd one! My friend's MacBook Pro had a broken O key, so he took it apart to replace the keyboard, but didn't know how to put it together so he gave it to me. I meticulously reassembled the machine, and now it won't power on! When plugged in the green light comes on the magsafe charger, and the battery indicators light up fine. Then, the sleep light start s to fade in, but abruptly stops. If you listen very very closely you can hear the fan initiate then stop in time with the sleep light. Took it to the Apple store where the technician said he couldn't figure out what was wrong, but that everything seemed to be assembled correctly. Have already tried SMC and NVRAM resets to no avail.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
How did you fix the keyboard? Did you replace the upper case or did you get the keyboard unit and put it in?
댓글 달기
답변 1개
가장 유용한 답변
See if it will spontaneously boot. Remove mag-safe. Unplug battery. Press & hold power button for ten seconds. Reconnect battery and mag-safe. You should get a boot. Then see what you can find out.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I did try removing the battery and using the Power Adapter, and at the Apple Store the technician tried that method to jump start the machine, the same sleep light/ fan sequence occurred.
댓글 달기
귀하의 답변을 추가하세요
Luke Miani 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 97
