주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
750 질문 전체 보기
MacBook Pro powers on only when keyboard disconnected after water spil
My wife spilled water on her early 2011 Macbook Pro unibody. It was closed when the spill hit it.
It has been sitting for about a week now and there are no signs of water. Unfortunately it won't power on. After some tinkering under the hood and trying to no avail to get it to boot via the power pads, I discovered as soon as I flip the retaining flap of the keyboard cable it powers up immediately. It boots up all the way with trackpad functioning but no keyboard (naturally).
Is my only option an entire upper case replacement?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
3개의 답변
선택된 해법
I believe you accidentally did a spontaneous reboot by disconnecting the mag-safe then disconnecting the battery then replacing them. You can do it again just to check. The if it won't power down or restart from the power button, the keyboard has been shorted out and need to be replaced. If this is the case let us know and we can get you to the guide to do that.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
가장 유용한 답변
The keyboard could be shorting the power rails responsible for turning the laptop on or resetting the SMC (SMC_RESET_L). Replacing the keyboard will most likely solve this. Fortunately, you can replace just the keyboard, it is quite a tedious job though, as there are many small screws that hold the keyboard into the top case. There are quite a few guides for it on the internet :)
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Cant reset smc without keybord... Key bord is the culprit needs to be replaced...
의 답변
의견 추가하세요
You probably have a bad trackpad and maybe keyboard. Try a new trackpad first and I bet your MacBook will work.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
The trackpad functions fine when it boots up with keyboard disconnected.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Jason 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 79
