주요 콘텐츠로 건너뛰기
Bissell's Bolt ION 2-in-1 Cordless for large rooms or smaller areas with detachable, handheld vacuum. Model number: 1312.
Why isn't my brush roll moving?
My brush roll won't move because there is something stuck.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I have taken the brush assembly apart and cleaned any buildup which was minimal. It will spin sporatically. Most of the time not.
댓글 달기
답변 2개
가장 유용한 답변
Open up your vacuum cleaner and check the belt. It likely has snapped or snagged and needs replacement.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
ok, I ll try your recommendation, but still need the replacement that goes closer to the bus . The roller cover please. Would you help me?
댓글 달기
the brush is ran by a belt. check to see if it has come off. you will have to remove the bottom but it is usually a phillips head screwdriver to do so.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jasmine soria-gamino 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 560
